Old 06-17-2015, 10:04 PM
sbleich sbleich is offline
Default 73 Electric Lift
I see that IH offered the electric lift option on the 73. I have a 73 and an electric lift and would like to install it. My question is, where would the switch go? Would IH have made a special dash for the electric lift option? Anyone out there have this option from the factory? Thanks for any help!
Old 06-17-2015, 10:09 PM
There should be a chrome knock out in the upper right hand corner of the dash for the lift switch. That was used for the cig lighter or the electric lift switch.
Old 06-17-2015, 11:11 PM
Pretty sure that the elift was not an option for the 73,even says it in the owners manual,not sure how it would work on the low tunnel frame.
Up to 530 and counting...
Old 06-17-2015, 11:27 PM
I have the "50 Years of Cub Cadet" and it lists it as an option.
Old 06-18-2015, 10:17 AM
My 1970 parts and accessories brochure list it only for the 106 107 126 and 127, but the hydro one is,sure you can put it on,but there will be no guard,and your switch will be below the ign switch,there is a chrome knock out there.Not a good spot for it,I can see the knob getting broken off.
Old 06-18-2015, 11:20 AM
Sometimes these books and illustrations are incorrect. What's wrong with this picture?
Old 06-18-2015, 11:35 AM
No Pabst on the picnic table?
Old 06-18-2015, 12:10 PM
Attachment 66173
Does it say 147?
Old 06-18-2015, 12:24 PM
yes it does,this one say's it too,and the udder one is a 107.
Old 06-18-2015, 12:28 PM
mattoney mattoney is offline
Attachment 66173
To answer your question: It was a 149 labeled a 147, and there's no PTO belt going to the mower deck. You can see the pulleys on the mule drive.
I've got the Book "Original Farmall Cub and Cub Cadet" by Kenneth Updike and that 147 appears two or three times. He described it as a test mule in disguise.
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
