Old 04-29-2015, 11:30 PM
budscub's Avatar
budscub budscub is offline
Default Feeling your pain
Your last post got me thinking, you may want to make sure you re not missing any air cleaner or butterfly plate screws, Just a thought to go with the statement of finding something in the combustion chamber.
I understand the statement of bugging you every minute. These little beast seem to do that to you when somethings not right with them.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 04-30-2015, 02:26 AM
Originally Posted by sawdustdad View Post
These "remote diagnostic" exercises are always interesting. So I've been following the discussion. I usually side with Jonathan on these, based on his extensive experience (and he's usually correct) but I'm curious what about the symptoms points to valves?
Can't give away all the secrets before the bets are made!
You are right about timing though Frank. It is possible.
I'm sticking with valve issue.
(Just so it's clear, that's a non-specific claim..... ANY issue found with valves is my bet. Not just "out of adjustment"...)
Old 04-30-2015, 12:26 PM
Frank in Foresthill Frank in Foresthill is offline
Not knowing just asking.
Does that engine have an "Automatic Compression Release"?
Old 04-30-2015, 12:39 PM
Yes.
Old 04-30-2015, 02:38 PM
Terry C's Avatar
Terry C Terry C is offline
I think since the stakes on this bet are so high I'm going to ask for more than just valves.
Since it was just rebuilt I'm going with not enough stem to guide clearance, maybe the reamer they use had reamed too many guides and was worn.
It's just a guess though. And I'm usually wrong!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-30-2015, 08:08 PM
OldSkull's Avatar
OldSkull OldSkull is offline
You play it safe...
This included the valves, valves seat, valves guide, valves spring and even the small levers on the camshaft that trip open the exhaust valve at low turning speeds to reduce compression.
Smart bet
Gilles.
1963 100 (red)/in storage
Old 05-01-2015, 02:29 AM
Originally Posted by OldSkull View Post
You play it safe...
Smart bet
So far I'm the only one who says valves, so we'll see if I'm right.
Old 05-01-2015, 09:15 AM
snoel's Avatar
snoel snoel is offline
Yup. Valves it is.
Steve
Old 05-05-2015, 09:23 PM
sgt.porter's Avatar
sgt.porter sgt.porter is offline
Had a little time to poke around the cub this evening. My feeler gauges went AWOL, (I have 3 boys and share property with grandpa, common problem), but I don't need them to see what's going on.
Basically, the exhaust valve is slightly opening during the compression stroke!
Watching the valves and the piston (through the peep hole) with breather removed, turning engine clockwise (from drivers seat):
1. Intake valve opens as piston moves downward (aka intake stroke)
2. Piston moves upward (aka compression stroke) but about halfway through the stroke, the tappet presses on the exhaust valve, slightly opening it (observed at tappet and through spark plug hole)
3. Power stroke seems normal
4. Exhaust stroke seems normal
I'm not an engine expert, but I'm pretty sure it's not supposed to work like that. As stated, the engine acts like there's no compression, now I can see that is exactly the case.
I took video, but no idea where to put it or how to post it.
So, what's next?
1. Is it common (or not so common) to have a cam (Lifter? Roller? I have not got that far in studying these engines...) slightly out of round, and a proper valve adjustment will compensate for the difference?
2. Should I stop messing with it, stop turning the engine, learn how to tear down and rebuild and then do it before I screw something up?
Still irked about the whole situation. It would be one thing if I bought the cub from Joe Shmoe with a yard sale sign, but this came from an IH Dealer/Family, I drove it out of a barn full of cubs (talked with the owner about making a future offer on a broke down 108 shoved in a back corner), one of the guys ran back to the dealer shop to grab the 4" binder full of every manual I could want, I spoke with the guy who had just rebuilt the engine, claimed he'd done it for the shop all his life. I never imagined I was driving 2 1/2 hours and paying good money for a cub that would blow up 10 min after I got home...
In other news, blew a pretty bad oil leak in the 680 while mowing today. It was too hot to mess with so I haven't even pulled the engine shrouds off to see where it's coming from.
Apparently, my comment about 5 K series engines and never having to do any internal engine work is coming back to haunt me...
LT1050 w/ 50" deck, 680 Hydro w/ 38" deck, 1450 w/ 50" deck, 109 w/ 38" deck
1A tiller, 42" snow blade (x2), cw-36 snow thrower, H42 snow thrower, #1 cart, 8" Brinly plow, Unk cultivator, Sears rear blade, extra k301, more extra decks and parts than space to put them.
Old 05-05-2015, 09:30 PM
j4c11's Avatar
j4c11 j4c11 is offline
Why does that feel like deja-vu?
http://www.onlycubcadets.net/forum/s...ad.php?t=36455
Read posts 5 and 6.
Tags
1450, compression, international, k321, starting
