Old 05-22-2014, 03:33 PM
yeeter yeeter is offline
Default Primer paint codes
Hi all,
Im anxious to use the holiday weekend to spray some parts, and am in need of primer. From the suggestions here, its recommended to use a high zinc epoxy based primer.
Does anyone have a specific model/part number?
The NAPA has a Martin Senour PIP101 This appears to be a basic primer
And my local PPG store has a MP282 (they dont carry the JP 202 shopline product). This is a 2k primer (has a catalyst with it I think)
But its not clear to me that these PPG or Martin Senour products are 'high zinc' content
Sooooo.... can anyone here offer up what their particular primer model numbers are? (high zinc epoxy primer)
Old 05-22-2014, 04:29 PM
A 2K primer IS NOT an epoxy. There are several epoxy primers. They really should be followed by a 2K primer. Epoxy is not considered a "sander/filler" primer. I suggest (as I always do) using NASON paint. But PPG has a good epoxy too. I just like to lay the same brand on top of each other. Not a good idea to mix paint brands. I stick with NASON. Their epoxy is called Full Poxy number 491-16 with a 483-19 catalyst. Don't get hung up on the "high zinc" content. It's not a big deal. Just worry about getting a good name brand primer (if that's what your looking for).
Old 05-22-2014, 07:52 PM
Thanks jmech
Neither the napa nor the ppg personnel seemed to know of an epoxy based primer. Hence I was asking for a specific number to quote to them
Old 05-22-2014, 10:20 PM
Cool. There is another primer, that I haven't used yet, but a friend of mine paints more equipment than I do, and he's switched to it because it's so much cheaper than the Nason. I'll try to get the info and post back. I can't even remember if it's PPG, or what it is. I just remember it's like $30 a gallon cheaper.
Old 06-19-2014, 04:17 PM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
PPG makes an epoxy primer. Depends on what color you want as a base, but they are DP50 is a gray. They make it in different colors. It is a good primer, and as said, it needs to be covered by a sandable primer.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
