Old 02-03-2014, 12:04 PM
ssechrist ssechrist is offline
Default Snow Plow Wings?
I got the opportunity to do a little snow plowing this winter as we don't get a lot of snow here in Oklahoma. I had an idea while out plowing yesterday. Plowing works very well when I angle the blade & roll the snow to grass but when I have to push it an end it seems like I spend a lot of time picking up the overflow trails.
Has anyone ever rigged up wings on a snow plow? I think the blowers have something like this on them.
I may try to come up with a plan for this so any input would be great.
Old 02-03-2014, 01:52 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I thought about it but I haven't yet trick is to get it strong enough yet make it easy to take off in my case due that I push gravel so I need to take off don't to have take all day to do it
Old 02-03-2014, 04:38 PM
You could split your blade in half and engineer a V-plow. When I plow sidewalks that are narrow, I HAVE TO angle my blade or else I end up with a lot of pieces of other people's yards in front of my blade at the end because their sidewalks are so narrow.
Old 02-03-2014, 05:19 PM
The idea I came up with is pretty simple. I was gonna use the top brace on the back of the blade & attach bushings on both sides then either one solid shaft all the way across or two separate shafts (one on each end) to attach the wings to. This way I could swing the arms up out of the way. I was thinking about using 1/8 or 3/16 sheet metal for the wings & 1/2X1/2 angle to frame around the wings for strength.
Old 02-04-2014, 07:13 AM
Looking forward to your build!
Old 02-04-2014, 12:38 PM
Same here!
Old 02-08-2014, 03:07 PM
CNeubauer CNeubauer is offline
You could even copy the Pro Wings that are popular on pickup snow plows.
Old 02-08-2014, 07:53 PM
Same here. I'd love to V plow the sidewalk, it'd make it easier. That being said, I would rather not have a sidewalk going through my front lawn all together.
Old 02-11-2014, 05:57 AM
cdlong's Avatar
cdlong cdlong is offline
There are some posts on here where that's been done. As I remember, one had wings on both sides and one had a wing on the right side.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
