Old 10-03-2013, 09:23 PM
cub102 cub102 is offline
adding get a set of new chrome caps wheel covers where to get and how much$
the have survived the crashes and bashes but have surface rust and need replating
Old 10-03-2013, 09:43 PM
I think it's on the rear axle tube on the back on the left. Should be a tag riveted on.
Old 10-03-2013, 10:12 PM
jeepchicken5000's Avatar
Welcome to the forum from a ct resident :-)
1981 cub cadet 682
1966 cub cadet 122
Old 10-03-2013, 11:17 PM
EricR's Avatar
EricR EricR is offline
Originally Posted by cub102 View Post
i posted this question elseware here do you find the serial numbers on a
102 Ih Cub Cadet
Welcome cub102. If you look on the right side of the rear end there should be a little block that sticks off from the rear (in the middle of the block) it should be stamped there. Our 102 has it in that location and it was made in Dec of 65, hope that helps.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 10-04-2013, 09:52 AM
FlyingB FlyingB is offline
Phil
A nice 1710 and QA42A snowblower.....and more to come .
Old 10-04-2013, 11:46 AM
Old 10-04-2013, 10:29 PM
Default serial # location
Ok, here goes.
I took a look from bottom rear view left and right
Axel tubes and looking from the side rearward view from
front of fear wheels no riveted tabs no small machined block with stamped #
Just some casting #,s on both sides of tran/rear end
any other areas that may be shrouded by sheet metal
Old 10-06-2013, 06:55 AM
j knight j knight is offline
Welcome to OCC.
Old 10-06-2013, 11:56 AM
ok i looked and talked to a few other cub owners at the zagray show
they showed me on theirs,
the numbers are stamped right into the casting on the right side of the trans right next to the parting line for the reduction housing, no raised block and no pined tab/plate
