Old 07-22-2013, 08:42 PM
jackblack's Avatar
jackblack jackblack is offline
Here is a picture of the double pulley
Old 07-22-2013, 09:38 PM
hhc70 hhc70 is offline
I don't think Cub Cadet ever used a double pulley PTO. John Deere did. Is it possible the engine is a transplant?
Old 07-22-2013, 09:50 PM
Or the clutch was a transplant. I don't think it will hurt anything. Might even be a good thing!
Old 07-22-2013, 10:37 PM
rweaver rweaver is offline
ok that looks to be a deere clutch and neither is for a 5/8th belt both look like 1/2 in and cub uses a outer cage to keep the clutch from spinning if it was mine I would replace clutch and use a 6in pulley at that time but its not mine
Old 07-22-2013, 11:03 PM
I didn't see that.... nor did I think about it. Good eye Ray!
Old 07-23-2013, 05:31 AM
jackblack's Avatar
Thanks guys. I will go on a hunt for a new clutch.
Old 07-23-2013, 07:57 AM
if you would send that clutch to me I could make up a clutch using some of the parts you have if not I think I have everything you need
Old 07-23-2013, 05:24 PM
KayakDon's Avatar
KayakDon KayakDon is offline
You will want the 6" pulley on the PTO. The smaller one will not work very well. The blower will be more like a plow. With the 6" pulley, the blower is almost unstoppable.
Old 07-23-2013, 06:38 PM
jackblack's Avatar
Thanks Ray, but I will check with my local dealer to see if he has what I need. He is also a collector and saves lots of used parts for resale.
