Hello,
Had a roll pin snap late this afternoon . Its the pin that at the rear of the drive shaft that holds the coupler to the hydro unit. What size is this ? ... can I get one locally ... or is this a Cub Cadet part I should send off for ? tks for any info Bryan ![]() |
it should be just a standard 1/4 spiral roll pin. heavier the better. might want to check everything out and see WHY it snapped?
John, PROUD OWNER ![]() ![]() ![]() |
Just get a grade eight bolt and double nut it. So much easier.
thanks you guys ... I'll remove the shaft and take a look. The motor runs fine..when I remove the shaft i'll spin the input of the hydro and feel if seems normal. I was going from reverse to forward when it happened. Everything is dry etc .... and the Coupler holes don't appear out of round or any noticeable cracks etc. When I put the tractor back together I used the pin I took out...the original I suppose.
I'll check it out tomorrow night. later, B. |
i don't reccomend using a bolt it will not be tight in the hole and will egg the hole out in the shaft
I don't think there are very many other people here who would reccomend using a bolt either...
Put a good quality 1/4" spiral pin back in there and providing nothing is wrong with the hydro trans, you should be good for a long long time.
Any good farm implement store, especially a Case IH dealer worth their salt will have SPIROL pins in stock.
Dave S. |
Now I get it. SPIROL is a brand name of spiral pin.
Here is the real culprit .... when it let loose it sheared the pin ... also put a hole in the top of my filter.
Anyone have a rear drive couple they would sell me perhaps ? Bryan |
Duct tape for the filter, JB Weld for the coupling!!
![]() ![]() Sorry to hear about the failure!! ![]() |
