![]() ![]() Check out our tech section for the manuals. Binder Books also has can provide a hard copy for less money then the cost of printing and paper. You did good! ![]() |
sam that sounds good! im down for whatever you think is better!
![]() ya after searching many many threads! i came across the tech section. is there a specific type clutch i have to use, im thinking i may be missing more parts then originally thought! i really wanna figure out how to up the auger speed a little too, i plan on using all new higher end bearings. i started tearing it apart today, and already found a few pieces that need to be re welded on, and a whole lot of sand blasting needs to be done, lol
matt (TK) 1952 buick special 1971 cub cadet 147 hydrostatic 19?? simplicity stallion twin 7 (soon to be f/x racer) |
Welcome to OCC
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
Awesome find and I agree, you did really good on the tradeout. I'm in the middle of a 147 restoration myself, so I'll try to check in on this thread to see if I can screw your tractor up too!
Nice 147 and implements.
Regards, chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
As for speeding up your auger, I would leave things alone, or you maybe opening up a can of worms.
The design of these tractors and the way they worked with the attachments is hard to inprove. Everything works well together ![]() By the way, welcome to OCC, and nice 147, I have one and really enjoy it.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
