Old 04-01-2012, 09:33 PM
brentwd's Avatar
brentwd brentwd is offline
Default 782 Hydro valves
I have a 782 with a valve leaking out the hole in top. Is this a o-ring leak or is it something else? With the tractor running you can see the fluid coming from the little hole in the top. Any ideas?
Old 04-01-2012, 10:57 PM
Time to replace these valve(s).
Old 04-01-2012, 11:14 PM
CubDieselFan's Avatar
I had this problem last year. All the info you need is in this thread. I ordered mine and go them in about 3 weeks. They did not have them in stock, they were back ordered.
http://onlycubcadets.net/forum/showthread.php?t=11917
Old 04-02-2012, 03:23 AM
TheSaturnV's Avatar
Or look on ebay for the new rebuildable valves that are now available. In the future you'll be able to simply pop out a snap ring and replace the o-rings yourself for a few bucks.
Old 04-02-2012, 12:26 PM
Ikea6e Ikea6e is offline
Hi Brent,
A local dealer told me he often cured that leak by using an impact hamer on top of the valves to jar loose any derbies that got stuck in the valves.
Don't know if it works or not, I never tried it.
Ike
Old 04-02-2012, 12:58 PM
TheSaturnV's Avatar
Sounds like the tale I heard about an official dealer fix being to plug up the top hole with JB Weld, stopping the leak and rendering the valve useless.
Old 04-02-2012, 04:38 PM
brentwd's Avatar
Just talked to LJ fluid power and they said the auto valves are 60.60. When I get the money I will get a pair. Thanks guys
Old 04-03-2012, 01:59 PM
klindstedt klindstedt is offline
Default Same problem with my 1811
I have the same issue with my 1811. I'm trying the guy on eBay that rebuilds them for $35.00 each. He has good feedback...I'll have to see what I get back. Hard to argue with $74.95 for both valves versus $121.20 new, although *that* is an excellent price.
Old 04-03-2012, 02:23 PM
Price them out at your dealer and you'll see that's a good price. For me for the price diffrence and the work I'm putting new in but that's me.
Old 04-04-2012, 02:08 AM
TheSaturnV's Avatar
I used his service and it was very quickly done. All the internals are worked over and the valves are like new. As I mentioned above, this is the same guy who is now offering rebuildable valves, where the end clip becomes a removable piece and the o-rings can be replaced for just a buck or two.
