Old 12-17-2013, 10:00 AM
CTorris CTorris is offline
Default Cub Cadet 1440 Latch Assembly, Quick
Attachment Snow/Dozer Blade:
Blade mount to quick latch keeps popping out.
Does the quick latch wear out? If so is there a quick fix? Seems like the quick latch rod ends only cover approx. 1/4 or less of the plow mount rod.
All Help Is Greatly appreciated! TY
Cly
Old 12-17-2013, 10:03 AM
Can you get a couple pics of it?
Old 12-17-2013, 10:06 AM
yes 1 minute please. gotta goto garage brb!
Old 12-17-2013, 10:30 AM
Latch Rod is up to the frame
Old 12-17-2013, 10:52 AM
It looks a little worn but I've seen worse. What I don't see is the part that should come down to retain the pins on the implement. This is the best pic I have of how it should look.
Old 12-17-2013, 10:56 AM
Correct.. That's the problem!
Old 12-17-2013, 11:15 AM
Well the area in red in this pic should drop down to lock the implement in the hitch. The latch is held in by the 2 pins that it pivots on and a spring. It could be bent or worn. You will probably need to pull it out and see what is going on. The spring should hold it in the latched position.
Old 12-17-2013, 11:44 AM
cubs-n-bxrs's Avatar
The spring is weak on my 1641 so I tie wrap the latch lever tight to the frame.
Old 12-17-2013, 11:46 AM
Latch rod does not appear to be worn.
Old 12-17-2013, 11:54 AM
It looks pretty good. Could still be bent or the spring could be sacked. If you hold it up against the front of the frame do the cams cover the slot for the hitch as they are supposed to?
Thread Tools
Display Modes
