Old 11-03-2011, 12:54 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Default Problems!!!
Originally Posted by CC1650Dave View Post
I'm certain I got the timing marks correct on reassembly. It's something I paid a lot of attention to.
If I can do the static timing method, and the "S" is dead on in the peep hole when the points break, I'd have to have the cam and crank timing correct, wouldn't I?
Wouldn't it be the case that the "S" mark couldn't be in the window at break, if the gears were off a tooth?
I think the cam could be off 1 tooth either way, you are the only one that will know for sure! I need to reread your whole post before I make any further suggestions. I don't want to send you chasing your tail, Unless you like that! As a rule carbs don't cause back-fire I have had some that dump fuel, you would have gas all over. The air filter will make a difference but only fine tuning, unless clogged. You could have bad Ign. components NEW doesn't mean good. I know it is frustrating after a lot of work but your missing something You'll get it!
Clay
