I have a 149 that I picked up very cheap in the north Ga. I,as well have been putting money in it..$20 here and there..it is still solid and stronger than anything Ive owned..Mine does slow down when warm and going up hills..but I recently cleaned the round cooler in front of the trans..and changed fluid and filter..it does not bog down anymore...I agree it is something I will pass down to the youngins..keep at her..she's worth it..If I can assist in any way let me know!
You explained that so well that even a simple dude like myself could understand it!! I do appreciate your explanation!!
Nice observation. I've always felt that these pumps perform better at max rpm. What's your guys opinion on plowing. I plow at full rpm because I feel the pump will perform better. I also feel it is better for the pump. I also feel it is better for the engine since it is air cooled. But, out of about 10 of us at a plowday this spring, I think I was the only one plowing at full throttle. Once guy was plowing almost at idle, you could hear the pump whining really bad.
I learned along time ago how much heat an air cooled engine can generate with my motorcycle. I ride a 600cc air cooled dirt bike and when it gets really hot and Im chugging her hard running 93 octane she will preignite and I can hear the pinging through the cooling fins. No cooling fans there.
WOT is the only way a Hydro should be used under load, plowing pulling etc...
Just for the fun of it attached is the principles on how the hydro work.
axial piston fixed displacement motor, yeah about that. . . . simple, and simple I like:biggrin2.gif:. I always had a hard time with hydraulic theory and my brother has a bachelor in hydraulics, go figure.
Point #1, wide open throttle is governed to 1750 rpms by design (according to the Kohler engine manual). If you are driving a hydro, you have infinitely variable ground speed available unlike the manual trannys. For proper operation of the tractor, read optimum cooling and power transfer from engine to equipment, always run the engine at full throttle when under load. That is when turning the pto, pushing snow/dirt, or anything that requires the engine to work harder. That is verbatim from the mechanic at my local Cub dealership. Also, the mowers cut better when you control the ground speed with the gearshift/hydro lever instead of the throttle!
Point#2 the above mentioned mechanic told me that the reason a lot of older cubs seem to 'slip' when navigating a hill is because the spring in the damper control has become weak. The cheap fix (as opposed to buying new springs) is to remove the springs and to install either 5/16" or 3/8" lock washers over the t shaped plungers on either end. Upon doing this, my 129 no longer feared the hills and continued to pull without any further need of attention while I was mowing. I tried all the other fixes, clean fluid and filter, clean fins, adjusting the linkage, all to no avail until I installed the lock washers.
You might want to double check that...WOT is 3600 rpm on nearly every air-cooled engine I have ever worked on, including Kohler K-series...
| Thread Tools | |
| Display Modes | |
