Old 08-09-2009, 04:37 PM
Keith Bliss Keith Bliss is offline
Default Cub model 1535 info please
Where can i find some information and specs etc for a Cub Cadet model 1535? I take it, that it isn't a IH Cub. Is it a CCC?
Thanks
Old 08-09-2009, 07:23 PM
papaglide's Avatar
Kieth,
Its a CCC made 1990-91
Kohler magnum twin cylinder horizontal model M155 15 h.p.
3 speed direct drive with 2 speed creeper with aluminum case
16x6.50-8 fronts
23x10.50-12 rears
its a garden tractor
all info from Oscar Will's book:Cub Cadet the first 45 years
Old 08-10-2009, 09:53 AM
Originally Posted by papaglide View Post
Kieth,
16x6.50-8 fronts
23x10.50-12 rears
Do you know if the IH Cub tranny will bolt into the frame?
Old 08-10-2009, 10:01 AM
Will it bolt in? Yes. Will the brake linkage hook up correctly? Probably not. In addition, the driveshaft would have to be changed, as the iron rear and the aluminum rear are slightly different lengths.
Old 08-10-2009, 10:29 AM
Thanks Matt, linkage and drive shaft can be fabricated or maybe the IH stuff would work. Brian Miller i believe will make a shaft to ones specs.
Old 08-10-2009, 10:53 AM
You can easily measure for a new driveshaft yourself. I don't think a 582 driveshaft will work because the 1535 has a Kohler and the 582 a Briggs...I think the length is different.
Oh, and I wouldn't expect to get anything made by Brian Miller...
https://web.mo.gov/doc/offSearchWeb/...od=getOffender
Old 08-10-2009, 11:07 AM
That isn't the same Brian Miller is it?
http://gardentractorpullingtips.com/index.htm
Old 08-10-2009, 11:43 AM
papaglide's Avatar
IF it is, that's scary.
Old 08-10-2009, 01:51 PM
I believe so...there was a rumor awhile back...I guess it's true.
Old 08-10-2009, 02:29 PM
papaglide's Avatar
wtf !!!!!!!
