Old 06-09-2011, 11:32 AM
thesid thesid is offline
Default fuel pump question
Hello,
I am just wondering how the fuel is suppose to exit the fuel pump on a Cadet 2165? Should it be a constant stream of fuel into the carb or an intermittent stream?
I am trying to determine if the fuel pump is bad. (I also cleaned that dime size screen behind the pump already). Changed the fuel filter and made sure the gas cap vent was not plugged. The engine is the Briggs & Stratton V-twin 16 HP.
The 2165 will start up and then stop.
TIA
thesid
Old 06-09-2011, 12:43 PM
cubs-n-bxrs's Avatar
The fuel exiting the fuel pump is a pulsed stream as it runs off the engine vacuum. Sounds like you have either a bad fuel shut off solenoid valve or the connection is bad. When you turn on the ignition switch you should be able to feel the valve attached to the bottom of the float bowl click. If you feel no click and have 12v at the wire with the key on the valve is most likely faulty. Had to replace one on my 1641 that has a 16hp Vanguard.
Old 06-10-2011, 09:45 AM
Thanks for your response. The fuel pump checks out. I am trying to get at the fuel solenoid valve to see if it is fuddled up with dirt or whatever. Just having problems removing housing. Also checking ground conneciton.
Old 06-12-2011, 07:03 PM
oldsasquatch's Avatar
oldsasquatch oldsasquatch is offline
[QUOTE=thesid;77574]Hello,
Just resolved that problem on my 1440 that's got a V-Twin 14hp. A 1994 I bought brand new. Would start and immediately stall out. After cleaning gas tank, gas line, fuel pump and checking fuel solenoid. I pulled the top off the carb and checked the needle and float which all looked good. You can actually see the fuel solenoid operate when you turn the key.
Had it all reassembled and the same problem exsisted.
This time I pulled the top off the carb and located the brass nozzle or jet that let fuel into the lower chamber and removed that.
It had some fairly large holes that looked pretty clean, but then noticed the microscopic pin holes in the middle part of this brass rod.
I had to take a single strand of a 22g multistrand piece of copper wire and run it through all these tiny tiny holes and ta...daa!
Reassembled and started up like brand new!!
Got my hands on a carb cleaner called Sea Foam.... that will help too!
Hope this helps
oldsasquatch
1994 Cub Cadet 1440
1977 JD 210
2007 Kioti CK20
