Old 03-07-2011, 12:37 AM
young enthusiest's Avatar
Default Newbie paint help
Hey guys, how long and at what temps should I cure the Valspar spray paint on my tractor. I'm a total newbie at painting so I'm trying to learn as much as possible without doing it the hard way. Also, if you have any advice for first time painters, please post it here and help us newbies out. I know where only a few pages short of an encyclopedia, so please post
Old 03-07-2011, 09:14 AM
Spray can or with a gun, and if with a gun, did you use hardener? Temp needs to be at least 65F or so. That stuff takes about 6 months to cure if you didn't use hardener, and about a month if you did.
Old 03-07-2011, 11:14 AM
Mlamar Mlamar is offline
Default Always
Hey Young
Always at the minimum use a respiratory rated for painting, especially when using hardener (catalyst). I also suggest safety glasses. I had a very small drop of thinner splash in my eye once and was fortunate that the doctor gave me some drops to heal it. He said it could have cost me my sight. I always prep surfaces with soap and water and Klean Strip Prep All wax and grease remover. I mentioned that product by name because some of the other citrus smelling stuff is not good to use before painting. I find it leaves some kind of a film that repels paint. I etch prime bare metal and use a seal primer on old paint surfaces.. A tack cloth is a must before you apply the paint and never try to hurry the job. TAKE YOUR TIME. It is personally rewarding to see the results of a job well done. And always, always, always have fun.
Old 03-07-2011, 11:22 AM
127cub 127cub is offline
Default ???
Hey guys i cant figure out how to post a tread
Old 03-07-2011, 12:48 PM
Click "new thread" at the top of a page inside the forum you want to post in. Button is in same place as the "post reply button" here.
Guys, I used spray bombs, and I currently have the tractor under a tarp with a heater in it. It's about 35 celcius (85f) under there. How long should I leave it?
Good information so far, keep it coming!
Old 03-07-2011, 02:40 PM
MrGitrdone41's Avatar
I used a spray can on my 128 What i did was is to prime wet sand that with 400 grit. Then put on the main color of paint. Then let it sit over night then wet sand that then put on the final coat. On my cub it turned out as smooth as glass.I used Valspar from TSC. If you don't wet sand the color will be a shade lighter then stock color.
1988 1812,dual ports
1973 108
1968 125
Old 03-08-2011, 10:19 AM
cubcadet100's Avatar
cubcadet100 cubcadet100 is offline
I used a valspar rattle can from TSC also. I glass beaded what i could fit in the cabinet and used a good grey primer sanded and put two coats of paint following the directions on the can it says to recoat within 4 hours i let it sit about an hour then put the second coat on. My shop is about 60F all day
Original, 100 with fenders creeper lights 3pt spring asst., 147 with electric lift IH hubcaps, 102, 126, 682 QA36 snow blower, 2 Dozer blades, Haban sickle bar, John Deere 60 Lawn tractor with deck and snow plow, 1962 Fordson super major backhoe, 1941 Allis Chalmers WC
Old 03-08-2011, 11:35 AM
Heres how some of my parts came out after 2 coats of primer and 3 coats of paint
Old 03-08-2011, 01:04 PM
Your paint job looks awesome, cubcadet100!
Old 03-08-2011, 03:08 PM
Thanks, This will be my first ground up restoration so im trying to take my time but want to get it finished in time for the county fair in july so i can put it in the show field, ive been giving dads glassbead cabinet a workout here lately lol
