Old 02-22-2011, 07:20 AM
JSFRIED215 JSFRIED215 is offline
Default 1641 whines
I have a 1641 thats starts right up runs good. The problem is at first when going forward it whines like crazy, it goes almost all away after running for 10 minutes. Still whines slightly at highest speed, or going up hill. Fluid levels are good. Help please.
Old 02-23-2011, 09:19 PM
PurplDodge's Avatar
PurplDodge PurplDodge is offline
Change the Hy-Tran fluid and filter (with a WIX 51410, NAPA Gold 1410, or Cub Cadet filter).
1992 Cub Cadet 1440 1,400 hours, 44'' Deck, 42'' IH Dozer Blade, Light Bar, All Trail tires,
16 year old Cub Cadet owner!
Old 04-20-2011, 09:46 AM
Default Still having problems
Ok, so i change fluid with all cub stuff. Still having problems with weak power and whining. I did notice that with the dump valve in the up or down position tractor can still be pushed. Is there and adjustment?
Old 04-20-2011, 12:06 PM
Dave01's Avatar
Dave01 Dave01 is offline
I'm not sure what you mean by weak power, can you describe what is happening?
As for whining, these hydros whine quite a bit, it's normal. When I first bought my 1864 I wondered if something was wrong, but it has run perfectly for years now, whining all the way. When I steer it really brings the whine up a note, just that small power steering ram is enough to put a load on the pump.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 04-20-2011, 12:59 PM
Default Loss of power
The loss of power i have is on an incline. On a hill the tractor almost stops. What tips me off is no matter if the hydro dump valve is up or down i can push the tractor pretty easily.
Old 04-20-2011, 01:10 PM
cubs-n-bxrs's Avatar
JSFRIED215 my 1641 pushes very easy also no matter what state the dump valve arm is in. I think I would take off the tunnel cover off and make sure the dump lever is going all the way down. Could be hanging up slightly letting the hydraulics bleed over a little bit when running.
Old 04-20-2011, 05:32 PM
TheSaturnV's Avatar
Bad relief valve(s)?
Old 04-22-2011, 07:20 AM
Default Problem solved
So i had time to take a look last night and found that the top lever wasn't pushin the arm to to relief valve all the way down, reworked the linkage and it runs like a different tractor. Thanks for the help.
