Old 01-16-2011, 10:38 PM
Default Let see your Previous Owners Modifications
I hope this is okay to do...
I started taking pictures of the PO mods done to some of the cubs I bought over the years,so I will start with these.
Old 01-17-2011, 07:06 AM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default awesome
This is a great thread !!! Sort of a what not to do !! Or maybe someone did something good....
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 01-17-2011, 09:35 AM
I wish I had taken pictures of more of the mods I have seen. Here's a few of the ugliest...
My 782D as I bought it
107 with a really poor choice of a seat
'The Batmobile' (used to be a 71, only complete tractor I have parted. That's a Wisconsin engine and truck rear wheels and tires...the bolt pattern on the wheels didn't match, they only used a couple of lug bolts)
Red 102 (paint reacted with the original paint, so all of it was falling off)
I haven't bothered to take pictures of all of the bent nails and baling wire in place of cotter pins, bolts instead of spirol pins, etc. I wish I had taken a picture of the muffler that was on the 124 that had my loader on it...the original muffler was mostly rusted out, so the PO shoved a couple of random pieces of pipe in it to 'fix' it.
Old 01-17-2011, 04:43 PM
ihnick's Avatar
ihnick ihnick is offline
I've had a couple tractors with bolts in the drive shaft.
Nick.
Old 01-17-2011, 05:14 PM
IHinIN IHinIN is offline
My 126 had cotter pins in the drive shaft too. It also had some pathetic home made gas tank brackets held to the engine tin work with sheet metal screws, 2 of which were stripped out. The frame had been cut out to fit a 14 hp and then patches were poorly welded in after the frame was allowed to bend. They didn't even bother straightening it first.
I think my fix looks a little better.
Old 01-17-2011, 06:17 PM
mrcubcadet's Avatar
Adam, it looks A LOT better! :biggrin2.gif:
-105___ Tiller
Old 01-17-2011, 07:09 PM
Ditto!
Old 01-17-2011, 07:38 PM
cub123's Avatar
cub123 cub123 is offline
I never got pics of it,but the PO "fixed"the issue when the starter generator went bad on the 104 i have.What to do?Well the PO took a SG off a sears(turns the wrong way)and drilled holes in the side of the grill and made a bracket to mount it so it would turn the right way,it looked like it worked sooooo well with the SG sticking off the grill bouncing around with a 4 foot belt on it......
Old 01-17-2011, 10:51 PM
Default pin
Hmmmmm kinda the wrong size....
1969 Cub Cadet 127
#2 IH cart
48" deck
42" Front Blade
IH wheel weights
Old 01-17-2011, 10:56 PM
Sminkey
Guest
Posts: n/a
LOL! WOW is the any of the spindle shaft left!! I know I have to have a good pic of a PO's handy work:biggrin2.gif:
