Old 07-05-2025, 11:23 AM
CVACUB CVACUB is offline
Default Internal wiring on starter generator
Hello all. I have a 1965 cub cadet 122. I opened up the star generator to replace the brushes and found that the wire from the internal coil that attaches to the external yellow wire is snapped off at the bolt. Is that a crimp connector or a soldered loop? Also what size are the bolts sticking through the case for the red and blue wire because that post is crossed threaded. And my better off just purchasing one off of fleabag and rebuilding it or does a member have one they are looking to sell, which would be my preference.
Thanks
Ray
Old 07-05-2025, 12:22 PM
Back in the day, the internal wires were spot welded to the bolt studs.
I've silver soldered them back then but thinking you might get away with soft soldering but don't "mud" solder them.
Clean them well then sweat the connection so the solder flows into the joint.
Old 07-05-2025, 12:32 PM
ironman's Avatar
ironman ironman is offline
I agree with the spot weld.
There are repair kits available with new terminal posts. Not sure how they attach.
You could contact the seller and ask....
https://www.ebay.com/itm/20328114815...Bk9SR5iFlrb7ZQ
Old 07-05-2025, 01:33 PM
Ok so the same seller has just the posts since I already have the new brushes and bearing coming
Thanks for the assist.
Old 07-05-2025, 11:49 PM
Graflex45's Avatar
Graflex45 Graflex45 is offline
I just rebuilt 2 generators, a good one and a spare from a bunch of parts and replaced the terminals using the kit in the picture. The terminals take solder well. You have to use a good hot iron and -Rosin Flux-. Do not use acid flux like for plumbing or acid core flux. The acid will slowly corrode the wire and get into the surrounding parts and start corroding them.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
Old 07-07-2025, 05:33 PM
Acid core solder. I haven’t seen that in years. Im gonna use regular solder and flux not the water based flux either cause that’s total crap
Old 07-08-2025, 10:18 AM
Graflex45's Avatar
Use rosin flux meant for electronics. The kind that smells like sappy pine. you wont be able to get all the remnants of any of the washable fluxes out of the braid of the heavy wire and it will sit there corroding away. Rosin doesn't really react after it cools and solidifies.
I've seen so many old garages of collectors and packrats still -trying- to use old acid core solder and flux.
