So I hooked up a battery to my new 147 to see what was going on. The lights worked no problem, but they killed the battery pretty quick. The safety switch on the rockshaft is wired into a loop cause the armature broke off, I'm assuming this is ok to do therefore bypassing the switch? So I put some charge on battery and turned key and nothing, nothing on the electric lift either. Does there have to be ample battery power to make these work? If it's not my older battery then I'm not sure where to begin
Jude,
My battery on my 149 will power the lights fine, but not turn it over unless it has a strong charge on it. Try putting a stronger charge on it or change to a fresher battery if you have one handy and see what's going on. Also, if it has been sitting for a while, I put just a small capfull of carb & fuel injector cleaner or HEET in the tank and it cleans up the bad gas deposits out of the carb and helps it fire a little easier---but DO NOT PUT MORE THAN A CAP OR TWO IN AT LEAST A HALF FULL TANK. Cub Cadet 123 |
![]() Quote:
Has that tractor been sitting outside a lot? The 1x6/7 series is notorious for wiring deterioration. I would seriously consider replacing the wiring before you go too much further. It sounds like you may have some broken wires and short circuits going on in there.
Did u hear a click when u hit the key? It might be the seloid?
![]() Quote:
You didn't say if you cleaned all the ground connections, cleaned the points, plug, traced and inspected all wiring, the lugs on the solenoid, spade connectors, v/r connections, s/g connections, etc. I would start with a fresh battery after everything is clean and inspected, then you can trace for problems if it doesn't turn over....Shouldnt be too tough ![]() Have fun! Jeff (teet)
CCC 1211 71 127 ![]() 102 122 1962 Original |
Ok, I did a look over of all the wiring and it's in pretty good condition. Pretty sure this tractor was kept indoors most of its life. I got it to turn over now and the electric lift works well too:biggrin2.gif:. Weak battery was my problem, but being the novice I am I put the float back in the carb upside down
Could be timing or points....clean up the points set the gap and check for spark again.
Your making progress.... ![]() In case you've not been fortunate enough to view Matt's static timing procedure...enjoy ![]() Jeff (teet)
![]() Quote:
![]() thanks for the tip on the static timing, I did see that before but it's good to have it again, thanks!! |
![]() Quote:
![]() Jeff (teet)
Thread Tools | |
Display Modes | |
