![]() Quote:
Does the true 3 point hitch plate take the same length as the sleeve hitch set up? |
Sleeve hitch adaptor type lift uses lift bar #703-0408 and is for 782's w/ser #'s 719999 and lower w/IH cast iron differential housing.
Cat '0' type 3 point is used w/ser #'s 720000 and up used lift bar #703-0811 and the aluminum differential housing. Two different animals. |
![]() Quote:
I bet Aaron from Xtreme would give him the dimensions for the bar if He wants to make it himself. Aaron's bar is based On the OEM Cat 0 Lift Bar, not the IH 3 Point Lift Bar. If anybody has a standard Garden tractor with the MTD Made Cat 0, they could give him the dimensions as well for the Hydraulic Lift Models, used Bar 703-0811.
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force |
![]() Quote:
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I know it's public info, but Aaron already has the correct dimensions
Yup, I was agreeing with you.
Thread Tools | |
Display Modes | |
