Old 12-30-2010, 10:37 PM
angry1 angry1 is offline
Default Wiring a volt gauge into the system
I have installed a tach and I am working to install the volt gauge, I am deleting the hour meter and the amp gauge. The tach is installed no issues my question is where to run the volt gauge, off the hour meter the "a" terminal on the Ignition switch will that work? looks easy to do.
I can run it off the "B" terminal but looking at the wiring diagram I am a little confused on the how to eliminate the amp gauge and install the volt gauge while keeping everything powered like it should.
Where would you install it ?
Thanks
Old 12-30-2010, 10:49 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Put it across the hourmeter in the diagram. That gets power only when the key is on.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 12-31-2010, 07:07 AM
IF you want to eliminate the Amp Gauge, you simply tie the two Amp Gauge wires together.
Old 12-31-2010, 09:18 AM
Thank You for the answers that was the direction I was thinking about but I was not sure if that was the correct way to do it.
