Old 11-18-2022, 09:24 PM
Originally Posted by ironman View Post
Hydro tractors don't have clutches. 3-pin drivers are for clutch/gear drive tractors.
3-pin driver would bolt on (4 bolts) in place of your hub adapter in your pic.
At least I knew that my 125 didn't have clutch.
Or maybe I just haven't found the peddle yet.
Learn new stuff every day.
Hope you find a donor tractor to go with your engine.
Ken
Old 11-19-2022, 08:51 AM
Tagcab7 Tagcab7 is offline
Thanks Ken. I been doing some day dreaming about a donor tractor. From your pictures it looks like the engine could just as easily go in a hydrostatic unit if I used the slotted adapter.
Old 11-19-2022, 09:28 AM
Where are you at in Iowa?
I am 35 miles west of Dubuque if you are ever in the area.
I have several used hydro front couplers as well as new ones if you find a hydro for your engine.
That 3 pin driver is probably just stuck in between the fins on the flywheel for storage.
My situation this summer was just the opposite of yours.
Picked up a 124 with a trashed trans-axle but with decent engine.
Swapped in a good rear end from a 102 w/trashed engine and I will be back up and running soon!
Old 11-20-2022, 01:47 PM
I’m about 40 miles south of Des Moines Des Moines. Good to know another Iowa OCC member!I don’t usually get over your way but I appreciate the offer. Good luck with your 124/102 project. I have a 102 that I use for some mowing and snow pushing. I really like it.
Old 11-20-2022, 02:25 PM
