The PTO belt keeps slipping off the center pulley. From the side when the deck is down it appears to go into the pulley at an off angle. is this normal? If not what can I do to fix the alignment. I also find that my deck is missing the front roller could this be the problem?
If it belt is coming into a pulley at a funky angle that is probably not
the way it should look. I would get down and spend some serious time looking at exactly the way the whole thing works. Are all the pulleys free and lined up or has something got loose and not aligned. Is everything moving freely. Is the deck belt moving freely and turning the blades? The front roller you refer to, if you mean the roller that attaches to the middle of the deck and rides on the ground. I don't believe that would cause your troubles. Let us know what you see down there. The great news is the belt is slipping and not breaking. Ken |
Time to hit the manual and set the deck up properly.
Sounds like it's hanging way too low on the front. Start with correct tire pressure on all 4 corners and go from there. https://s3.us-east-2.amazonaws.com/c...ervice+Man.pdf Section 3 |
![]() Quote:
Hopefully, the correct size as listed in the belt charts also available on this site.
Thank you, thats a very good question. I'll have to find that chart and get some new belts.
Thread Tools | |
Display Modes | |
