I replaced the halogens headlights with LEDs this past winter and they worked fine until this past weekend. I didn't have my circuit tester available and I forgot to check to see if I had tail lights.
Are the lights on the 1862 fused? If so, where is the fuse located. |
There is NO specific fuse for the "light circuit".
Power comes out of the "L" terminal to feed the Head & Tail Lights on the blue wire. If you have lost both head & tail lights, then I would look at the Ignition Switch. If you only lost one, then I would look for a broken wire.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
The light problem was fixed. The LEDs failed so I went back to the old halogens I took out. The LEDs had less than 30 minutes of use so I am not sure why they failed so quickly. Both failing at the same time makes me think there was a current surge or a short of some kind.
Oh well, since I don't use the tractor much after dark I think I will stay with the halogens. |
| Thread Tools | |
| Display Modes | |
