Yeah Walmart did have 20W50 synthetic but it was also listed as motorcycle oil. It was around $9/quart.
Most list it as that. My dad ran into the same thing for his Z Force ZTR (also hydro gear transmissions).
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Ok I drained the fluid and installed a new OEM filter, then filled it with 6 quarts of 20W 50 oil. Checked the dipstick and it showed FULL. Drove it around and it seemed fine. No drips, no leaks.
Let it sit for 2 days and now dipstick shows ADD. I noticed it was not entirely level, so I disengaged the Hydro and pushed it forward a bit until it's level. Now dipstick reads HALF FULL. I don't see ANY fluid on the ground, where did it go? I don't see anything around the drain plug or filter itself, no way it lost 3 quarts (half) just sitting 2 days... |
approximate 6 quarts. Did you check your oil after running it the first time. I'm sure some oil level loss would be attributed to displacement into oil filter as well as splashed onto gears before settling down. .....So, I'm curious to how much more oil you will need to top off the dipstick. I bet it's less than a quart.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
By half full I mean between the ADD and FULL marks. It showed FULL after I drove it around post fluid change.
A reading between add and full means the oil is in acceptable range. So you are good!
Ok whew I was beginning to wonder if it all evaporated lol
Here is how to check your fluid per page #23 of the Owners Manual.
Here is the correct and proper Hydro fluid to use, per the Owner's Manual, on page #60. 737-3055, This part is replaced by 490-000-C051.
CC Model: 127 w/42" deckCC/MTD Model: 2155 w/42" deck |
My wife says I do not listen , at least I think thats what she said |
| Thread Tools | |
| Display Modes | |
