Old 11-08-2021, 07:33 PM
RLause's Avatar
RLause RLause is offline
A couple of links that might be helpful
https://www.onlycubcadets.net/forum/...ession+release
Richard
Old 11-08-2021, 08:07 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
Originally Posted by RLause View Post
Thanks for the links - hoping it isn't what's wrong with mine...
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 11-09-2021, 07:05 AM
Jim in SC's Avatar
Well I checked for the tab on the ACR just now. I think I've found the problem. No tab. Must have broken off some time ago in a previous life. Dang. I suppose that means that I have to replace the timing gear, right?
Sounds like an over the winter project...
Old 11-09-2021, 08:29 AM
Interesting,
You were asked in post #4 about the compression release.
now we are at post 33.
Not hammering on you, just saying .
Old 11-09-2021, 08:49 AM
Jim in SC's Avatar
Interesting,
I'm just trying to learn and this seems a good place to do that.
My next question is what part # am I going to need? There are a number of them on eBay with PN 47 010 06 , but some are for K241AS and some are off of a Wheel Horse, etc. I just want to make sure I get the correct part.
Old 11-09-2021, 09:42 AM
Cubcadet_107's Avatar
I'm pretty sure its the same camshaft for the k241, k301, and i think k321. Should look like this
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 11-09-2021, 12:51 PM
Red Dave Red Dave is offline
That looks like it. I had to put a new cam in the k301 in my 123 for the same reason you need one now. It was a non-running basket case when I got it. It is almost 20 years now, but my memory of it is that everything has to come out of the crankcase to get to it. Might as well check & replace anything that is worn like worn piston/connecting rod/crankshaft etc while you are in there. When I did mine, it needed a new oversized piston, re-bored, bearings and a new (used) crankshaft.
I don't remember it being a difficult job, but it did require a generous application of dollars for parts and machining. On the plus side, it hasn't needed anything internal since then.
Old 11-09-2021, 02:22 PM
Yup, almost everything needs to come out to get to it, other than the governor.
Jim, You don't need to go the route of a complete rebuild but its probably a pretty good idea to check over all the measurements and specs, especially if you don't actually know the condition of the engine. I mean everything could be really nice and just require a set of new rings, or it could be worn way out of round and need a rebore. Better safe than sorry imo.
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 11-09-2021, 03:54 PM
Jim in SC's Avatar
Dave, thanks for that input. I figured that I'd be having to do that. Dang. Good advice though on fixing up any other problems as long as I'm in there. For sure it'll be a "winter project!"
Old 11-09-2021, 03:59 PM
Jim in SC's Avatar
And a thank you too, CC107, for great response and advice, which I surely need! I'll take it slow and (hopefully) steady in the next couple of months. First off is to get a new gear/ACR!
