Old 10-16-2021, 09:24 AM
Stockmastercub Stockmastercub is offline
Default Relief valve drill tap and plug?
Hello...
1450 hydro relief valve (older style..not the ' push button' style) leaking from the tiny weep hole in top....i read where you can not just block it off because you can not 'push the tractor'....thoughts on drill n tap and put in a small pipe plug...if I do need to push the tractor I can remove the pipe plug? If possivbe, how far can i drill in ? Just about 1/4 to 3/8 deep?
Old 10-16-2021, 10:08 AM
mortten mortten is offline
The one without the button is an automatic one and actually the newer style. It is leaking out the hole because it is worn out. Contact this company. They can rebuild yours for a fraction of the cost of new.
605 Furnace Rd.
Conneaut Ohio 44030
Phone: 440-499-5813
Email: mark.machtech@gmail.com
Doug
QA-36A
42" blade
Old 10-16-2021, 11:54 AM
Originally Posted by Stockmastercub View Post
Hello...
Do not plug the hole, it needs to be there or the Tractor will not move.
Just think of it as if something plugged yer relief hole, you wouldn't move.
Then bad things happen
Old 10-16-2021, 01:03 PM
ironman's Avatar
ironman ironman is online now
It leaks now but it is repairable, as mentioned above.
If you drill and plug, and it doesn't work, you will have trashed a repairable relief valve,
and now you will be buying a condition unknown used one, or a brand new one at greater cost.
Make sense?
Old 10-16-2021, 06:36 PM
The hole in the top of the relief valve is a "vent hole". Do NOT plug this hole.
Old 10-17-2021, 07:59 PM
Thanks for the input...first time in my research I heard they could not be plugged. Makes sense !
Old 10-18-2021, 11:01 AM
Ambush Ambush is online now
No that it matters and everybody knows what's being talked about but; they are actually "release" valves and not "relief" valves. Hence why you can't push your tractor when plugged or for the older push bottoms, when they're in the up position.
It's only a terminology issue when someone says "shim your relief valve".
