Is it possible to change out the teaser spring on a 126 without disaasembling the whole clutch? I'm new at this. Seems to me that if I pull the engine, the shaft could remain in place and the spring could remain assembled and under tension (maybe I should even depress the clutch pedal to give my self more "room")? seems to me I could then just drive out the pins holding the two pressure plates, slide off the plates, then change the spring and re-assemble. I will also be changing the self-aligning bushing (pilot bushing)in the drive plate while I'm at it. Thanks in advance for any help.
It's possible but I believe you just be beating the crap out of yourself and the clutch even if you depress the clutch pedal. If this were mine, I'd just take it out.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
UPDATE: Actually, it was pretty easy (remember, I am new at this) I am in the process of stripping the tractor to pull the motor. I depressed and locked the clutch pedal....then i "just tried" to punch the pins because I had previously spayed WD40 on the pins.....I was wondering if they would budge because I was going to the parts store and wondered if I should get some pins while there. Well, they not only budged....they came out pretty easily with a long handle punch. There was no "tension" on the pressure plates and also plenty of room. Motor is still in but pins are out.
I put a piece of wood across the frame so the shaft rests on it. Then bang away.
I had the shaft support by a piece of wood on a jack at just the right height. But again, it came out pretty easily
. Now I have another issue, the cadet parts guy sent me the wrong pilot bushing. He sent me the "self-centering pilot bearing" instead of the bushing. The O.D. on this "bearing" is about .200 inch too big. I wish I could cross-reference it somehow so I could try a local autoparts store. |
Thread Tools | |
Display Modes | |
