Old 09-10-2021, 04:29 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Default Torque wrench for engine assembly
Which torque wrenches are y'all using when assembling your Kohler Ks? I have a 3/8" 20-100 ft-lbs wrench (and a 1/2" 50-250 but that's certainly not going to be used here ). Most in-lb torque wrenches for sale seem to top out around 200 in-lb, which is less than the 260 in-lb needed to torque the posi-lock nuts on my K241 connecting rod. Now, 260 in-lb is the same as 21-2/3 ft-lb, but I don't think I trust a 3/8" 20-100 ft-lb wrench to be accurate enough to hit that properly.
So, I'm in search of a good in-lb wrench that will do the trick here. Wondering what your thoughts are. Thanks
Old 09-11-2021, 10:25 AM
Billy-O's Avatar
Billy-O Billy-O is offline
My thoughts are that it depends on who made the torque wrench..... I wouldn't use any of the Harbor Fright crap or some other cheap brand. Go with a good reputable brand such as Snap-On, Mac or older Craftsman USA made wrenches. If your 3/8" wrench is the kind that has a "click" feel when you hit the mark, it would be hard to feel that click since it's on the bottom end of the wrench's range where the click is weak but I still use it if it's a GOOD wrench since it is in range. More important is to be consistent bolt to bolt and go over the bolts again after tighten them all the first time.
A good torque wrench is a considerable investment for two bolts...... Perhaps you can rent one or borrow one.... Some automotive stores will accompany you.
Plow blade
#2 Cart
QA36 snowthower
Old 09-11-2021, 01:05 PM
I find it hard to justify not buying a good torque wrench. Both of mine are Protos.
It is an investment for just two or so fasteners…but I ended up ordering a 0-300 in-lb dial-type torque wrench from CDI, the 3002LDINSS. I know this isn’t the last time I’ll use it.
Old 09-11-2021, 05:54 PM
SS5150's Avatar
SS5150 SS5150 is offline
I've got a Craftsman 10-75 ft lbs clicker type here at the house and a Snap On flex 5-75 ft lbs at work. I also have a SO 0-100 in lbs wrench at work. I think if you try ebay you should be able to find something similar in new or very good used condition for not much money. If I recall the Craftsman was under $50, but it's been 10 yrs since I bought it.
I wouldn't rule out a NOS Napa or KD torque wrench with the appropriate capacity either.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 09-11-2021, 08:30 PM
green407's Avatar
green407 green407 is offline
My primary torque wrench at home is a Mac tools TWXF75, it's a 3/8" drive, 5 - 75 ft/lbs. Now I bought mine used so it didn't cost me $400, but I did spend the $50 to have it checked and calibrated.
As for what I recommend, the best you can afford. I don't know how often you'll need it, but it's nice to have good tools. Yes I can afford a lot of Snap-on and Mac tools, but using my tools is how I eat and put a roof over my head.
128 X 2, 129, 149, 1250, 1450 x 2
Old 09-15-2021, 01:54 PM
Great tips and suggestions guys, thank you.
The torque wrench came in. This should work nicely for what I need (and many other situations in years to come). It's a nice piece.
Old 09-18-2021, 12:15 PM
SLS327 SLS327 is offline
That looks real nice! Did it come with a calibration sheet?
Even has the mip, which most those types have.
Fwiw i use a 3/8 craftsman clicker type, 1/2 matco 25 to 250 iirc, for really little things pittsburgpro 1/4".
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 09-19-2021, 06:57 PM
Yep, it came with a calibration sheet.
