Old 04-22-2021, 07:11 AM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
I really like the counterweight attachment
The Tractor is Looking Good.
Old 06-06-2021, 12:38 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
You did a really nice job!
1- 1200 in pieces
1- 1864 in pieces
Old 06-06-2021, 01:53 AM
jcsmith jcsmith is offline
Beautiful job Ambush. You are an artist.
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 06-06-2021, 02:02 PM
Love your build!! Looks great!
Did you put any reinforcement from the loader subframe to the rear end? The transaxle is only held on to the frame with 2 bolt in each side and it's the rear end that take the brunt of force on any uneven lifting in the bucket or side load from uneven ground. Without connecting the rear end to the subframe, a huge amount of stress goes on the frame area above the rear end. Just some food for thought.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 06-08-2021, 09:42 PM
IHinIN IHinIN is offline
Great job on the loader!
Old 06-13-2021, 12:15 PM
Ambush Ambush is offline
Originally Posted by Randy Littrell View Post
Did you put any reinforcement from the loader subframe to the rear end? The transaxle is only held on to the frame with 2 bolt in each side. Randy
Thanks Randy. I do have four more bolts attaching the rear plate to the frame but will eventually build a " torque tamer" from the bottom bolts on the axle tubes to the frame. I should have been more worried about the front axle though. There was some pretty deep grooves wore into it from flopping tiller belts over the many years and that was enough cause a failure.
Old 06-13-2021, 12:26 PM
Between fluid in the tires, factory wheel weights and the homemade plates there's 220 pounds, plus I can stack up to 310 pounds of suitcase weights.
Old 06-14-2021, 09:22 PM
Okay, that looks good. I have a loader on a WH and about twisted it in half till I built braces out to the rear end. It will eventually go on one of my 149's.
Randy
1 100's
2 149's
1 73
1 2182
