I'm new to the forum. I have been Googling a hydro-gear cross-reference for my hydro-gear SLTX1050 tractor, with zero results.
Does anyone know if a 618-0319 hydro-gear will replace a 618-04270b hydro-gear? My 2011 SLTX1050 tractor has the 618-0427B hydro-gear, and needs replacing. I have found used ones for $500 and above. I have found 618-0319 for around $200. Thank you, |
First welcome to OCC..........
![]() The Cub Cadet website states it is a Hydro-Gear "0610" transmission. I went to the Hydro-Gear website. Couldn't navigate well there. The best I can offer, is that the 618-0319 transmission was used on the following Cub Cadet tractors.
According to the Cub parts web site....
The 618-04270b (now 918-04270b) is a 610 model Hydro Gear. The 618-0319 (now 918-0319) is a 510 model Hydro Gear. Here is the service manual that covers both. https://www.hydro-gear.com/25a844c83...N-51260_P8.pdf There are exploded views and parts lists on pages 32-35. There are differences that appear to be external bolt on stuff. Your best bet would be to call Hydro Gear and ask. Assume you are aware of the recall on these so if you buy a used one, check the s/n. https://www.hydro-gear.com/25a844c83...web_recall.pdf |
Ironman:
Good information !! ![]()
Thank you all of you for the information. It is very helpful!
Having the same problem now. Years later, which model number did you go with? Thanks.
You only need two things in life: duct tape and WD-40. If it's loose and supposed to be stuck, use duct tape. If it's stuck and needs to be loose, use WD-40. |
Thread Tools | |
Display Modes | |
