Old 11-27-2010, 10:03 PM
bertw bertw is offline
Default IH 682 pto
I started my 682 for the first time after sitting for about 3yrs. and the pto squeels when not engaged, Does it need some lube or somthing more?
Old 11-27-2010, 10:43 PM
aagitch's Avatar
aagitch aagitch is offline
It may be the pto bearing which is replaceable.
Old 11-27-2010, 10:57 PM
ljones's Avatar
ljones ljones is offline
It could also be the air gap.
Old 11-27-2010, 11:38 PM
Should the pulley spin free or have some resistance?
Old 11-27-2010, 11:58 PM
If you back off the air gap adjustment all the way so the brake plate isn't contacting the rotor, it should spin freely and silently.
Old 11-28-2010, 10:15 AM
My 1811 did the same thing. When I removed the pto bearing it was seized up. I got a new 6206 double sealed bearing at Grainger for about $17.00.
Old 11-28-2010, 04:14 PM
The bearing is in bad shape. Thanks for all the help.
Old 01-04-2011, 03:09 PM
Frank1541 Frank1541 is offline
I have a question on the bearing for the PTO. The 6206 normally comes with and ID of 30mm, 1.179in. The shaft is 1.125in. It looks like cub has a shim on the inside to make up the difference. Are 6206's available with the 1.125 ID or has some one found the shim?
Thanks
