1969 cub cadet 124.
Trying to figure out my transmission leak on my 124 3 speed manual transmission. Earlier in the month, I replaced the o ring that goes on to the wet brake push rod and lever and the axle seals that solved it but I have a leak from where the drive shaft coupler meets. Is there another o ring sit behind that coupler? |
There is an oil seal at that point.
Shouldn't leak a bunch at that point as it is above the oil level. But certainly could produce a drip or two Should not leak continuously while sitting still. Seal, Reduction Drive Shaft Oil Part# IH-385076-R91 (Superseded to IH-385076-R92) OEM Warranty Repair Part for Cub Cadet #20 in the diagram
or with time, was allow there to be a slight drag/bind of the fiber disc and the small pins on the 3 pin disc plate. Also, if you don’t have those 3 springs, the center bearing on the 3 pin clutch can be worn out or not have enough lubricant. These will also cause your symptoms listed above. 027BBC76-8FA1-4F3A-A848-AA5EA211629F.jpg
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer |
Cub70 is spot on. Also, did you try to adjust the clutch? There is a screw that takes up slack in the linkage, Under the dash tower, at the bottom of the clutch actuator arm. Might be all you need.
The seal should be in the plate. Never replaced one myself, but should be able to do it without disassembling the reduction housing.
GREAT info,t hanks!
![]() ![]() ![]() '76 1200 Dad bought '75 1200 "Twinsie" per my daughter |
Very good information. My clutch assembly is worn out. My driveshaft itself have a groove in it, the throw out bearing making awful noise, the lever where it holds the bearing is loose and worn out. So, dropping a new assembly in seem wise to me. Dont use the spring on the new set up?
YES..... plus 7 more characters
No! Don’t use the anti rattle springs on your new clutch assembly!
Yeah I would not put them on that setup.
| Thread Tools | |
| Display Modes | |
