Old 01-11-2019, 02:17 AM
Steve N Mi Steve N Mi is offline
Default Brake pads/pucks for 1872
Okay, what do you guys do for brake parts no longer available? Cub Cadet 759-3424
Old 01-11-2019, 07:04 AM
This maybe a solution..... Brakes
Old 01-11-2019, 07:44 AM
dale c. dale c. is offline
check sponsors for used ones ?
Old 01-11-2019, 06:15 PM
Thanks guys, I did check the vendors above before posting this for a friend. I was hoping Jeff or someone would be making replacements - I didn't find any.
Thanks Roland for the link. I did find this one in a search
https://www.onlycubcadets.net/forum/...ht=1872+brakes
which is a little more recent but still long enough ago that, maybe by now, we have a aftermarket supplier for the disc brake pads/pucks.
Old 01-14-2019, 07:11 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
see if there is clutch and brake relining place near you they have matieral to redo the pads. i use Buffalo Clutch in cheektowaga, NY
Old 01-14-2019, 07:55 PM
It was a while ago,, I am working from memory here,,,
but, I wanted the brakes to work a little better on a 128 I was tinkering with,,
after installing new pads,, I still wanted better,,
I epoxied a square of 1/16" thick stainless steel sheet on the pad where the rotating cam contacts the pad.
The piece of stainless was about 1 inch X 1 inch, one piece for each side.
The stainless steel has much lower friction, so, the cam applies more pressure, with less pedal pressure,,
