#71
They're all painted!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]() ![]() |
#72
Looking good! Can hardly wait to see the end result!
#73
Looking good!
[B]Larry[/B] |
#74
The good...
Looks good when is assembly time?. The bad... I cannot tell, but are the brake rotors masked off? The other concern is the breather for the tranny, was that covered also?
#75
Thanks for the compliments!
Lew, I'm hoping to start reassembly next week. The brake rotors were not masked off, but the breather was.
#76
I am starting on my 149 rework and was wondering if you replaced the rear axle seals? If so I was hoping you could tell me where you got them and what size they are? Something appears to be leaking back there on my little gem. ;-) Thanks.
Wayne ![]() |
#77
I did not replace them, I don't think they were leaking on mine. I did replace the cork gasket though.
#78
Chances are it’s the relief valves and/or the cork gasket that are leaking. They are much more prone to leaking than the axle seals.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
#79
Ware is this leaking cork gasket I keep hearing about ?
#80
Between the pump and the transmission there is about a 3" dia cork gasket. Its a very cheap fix, but takes a good amount of labor. Search the forums you should find multiple references to it. Given the age of the machines, when You go in to do this $10 repaair, you can drop another $1-200 or even more in other needed things that you take apart in the process.
Thread Tools | |
Display Modes | |
