Old 09-29-2018, 06:40 PM
willys55's Avatar
willys55 willys55 is offline
Default 100 needs an engine
Well, now it needs an engine. I let the son-in-law use it, and he never checked the oil. It broke a rod.
64 Cub Cadet 100
Also have quite a few Non Cub Cadets in the Shed
Old 09-29-2018, 06:54 PM
That’s a shame willy. The question is though did you only let him use it once and it threw the rod or did he have it for a while?
Old 10-03-2018, 10:00 PM
willys55's Avatar
Once, he came over to mow my front yard because I have been overloaded with work and firehouse events. He never checked the oil, and according to my wife he was running it a full throttle from the very moment he started it. Oh well, not much I can do about it now.
64 Cub Cadet 100
Old 10-04-2018, 01:36 PM
Sorry to hear that willy, whatcha going to do for a motor?
Old 10-10-2018, 04:35 PM
willys55's Avatar
was thinking about calling you Lew
64 Cub Cadet 100
Old 10-10-2018, 04:40 PM
willys55's Avatar
I have 4 weeks of fire school to finish before I can even think about doing anything to it
64 Cub Cadet 100
Old 10-10-2018, 08:11 PM
"running it at full throttle from the very moment he started it" So? That's how most of them run and they need to be while mowing to keep blade speed up, you want to go slow then gear down using the trans.
as long as it wasn't being over revved, that wouldn't have done it. if the governor was working, it would not have over revved. unless he had his fingers in there holding it open.... probably just from normal wear and tear. those tractors aren't exactly new, now a days.
Old 10-11-2018, 08:16 AM
willys55's Avatar
Not my first rodeo, full throttle extended without load will cause damage, of course the bloody thing is old......but he didn't check the oil and he clearly ran it long and hard......either way, water under the bridge and now she sits till I have time to rebuild or replace.
64 Cub Cadet 100
Old 10-11-2018, 08:25 AM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
So did he run it without oil?
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 10-11-2018, 11:22 AM
I have a motor, and a few things for that f cub.
