#41
Looks good, glad you decided to remove the extra "stuff", and do this right.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#42
Thanks, Todd.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]() ![]() |
#43
I'm kinda late to the party here...
Did you tighten up the front axle "C" channel before painting? Also, I'd figure on new tie rod ends all the way around and a new axle pivot pin and maybe even bushings if they really need it. Go through the steering box and tighten it up, replace parts where needed, like the cam follower, and add the "super steer" bearing kit as well. And adjust the toe in as directed in the FSM so it steers nice and straight with minimal steering effort. You will be glad you did first time you drive it out the door. Nothing better than to mount a "restored " Cub and have it steer as it did when new, nice 'n' tight like a German virgin. So Far so good! |
#44
![]() Quote:
I didn't plan on replacing the tie rod ends, pivot pin, or bushings, but I will now. I was already planning on going through the steering box.
#45
It's the channel that the front axle pivots in.
Grab the axle by the end, try to twist it like it was a bolt. Then try to move it frontwards and backwards horizontally. If it moves fore and aft with a lot of slop, it needs some attention. Newer GTs have an adjustment to control this issue. |
#46
![]() Quote:
#47
I got most of the white parts painted today.
#48
I love seeing these restoration threads. Keeps me motivated to finish projects of my own. Thanks for sharing!
-Derek Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46 |
#49
The new white is looking good!
#50
Beautiful! Don't you just love the looks of freshly painted parts?
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Thread Tools | |
Display Modes | |
