Old 11-01-2010, 10:49 PM
Ewilliams's Avatar
Ewilliams Ewilliams is offline
Default IH 782 problems
I have a IH 782 that I picked up this summer. It has a kt17 (series 1) engine. I runs really well but every once in a while it runs rough. I replaced the coil and it seemed to take care of the problem. I've also rebuilt the carb, replaced the plugs, fuel filter, and tested the fuel pump. I used it for about 2 hours the other day sweeping leaves and it ran beautiful. I was getting ready to put the snowblower on and when I started it has a hesitation when it throttle it up. It backfired, also. It is frustrating because it is intermittent. Any advice or suggestions would be greatly appreciated.
Thanks,
Earl
Old 11-01-2010, 10:51 PM
ajgross ajgross is offline
Inactive Member
Backfiring usually means a timing issue. Timing could also cause your hesitation.
AJ
Old 11-01-2010, 11:01 PM
AJ
+1 for that.
Old 11-02-2010, 08:56 AM
You might check to see if the gap has closed up on the points.
it costs nothing and is easy to get at.
Old 11-02-2010, 05:55 PM
JayBrd's Avatar
JayBrd JayBrd is offline
Check to see how clean they are and if the condensor wire is tight also.. I just went thru and found that on mine..
Jay N.
Eau Claire, WI
RED 82 Series...
