Old 07-27-2018, 03:21 PM
I went with the 75/25 Mix.
That's what I use. I use .030 wire but mostly weld sheet metal and steel up to 1/4".
Old 07-27-2018, 04:26 PM
Being a novice in the MIG arena, in my mind, the solid steel wire is about all the same.
Thanks for the replies. I appreciate the input.
Old 07-27-2018, 08:39 PM
It probably all comes from the same place in China anyway.
Old 07-27-2018, 10:16 PM
Billy-O's Avatar
Billy-O Billy-O is offline
With the tariffs, I bet!
Plow blade
#2 Cart
QA36 snowthower
Old 07-28-2018, 10:20 AM
I use wire from weld coat metals, I have had trouble using older wire it seams maybe the gun liner is corroded some ?
I am on argon gas
Old 07-28-2018, 11:28 AM
Also, I would not try to set up a MIG with a regulator on the gas bottle.
You really need to get a floating ball flow meter,,
Too little gas flow, you get oxygen in the weld (bad)
Too much gas flow, you aspirate oxygen into the weld (bad)
There is only a narrow band of "just right" gas flow,,, the right flow meter will make sure you are doing the best possible.
Old 07-28-2018, 12:04 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The regulator that comes with the welder has a bottle psi gauge and the other is a dial flow gauge. I have not seen nor used that type to know if that is good or bad.
Mine has bottle psi gauge, a output psi gauge and a ball type flow meter.
Oh and............if you buy the small spools often enough and buy whatever brand is "on sale" you will eventually run into crappy wire.
Usually foreign made.
