I installed a external hydro lift on my 100 and everything went good have it hooked to the 3pt and using the cultivator. Got thinking about the snow blade the other day and was wondering how the front attachments hooked into it. I have the thing that would usually u bolt to the lift rod and i seen in the directions that it has to be cut down but do you drill a totally new hole and use a spacer or do you go in the same hole that bolts through the cylinder. And 1 more thing, what is the deal with float on an external unit like this? I will grab some pics and post them in the morning
thanks |
First thing you need to do is read the installation manual in the technical library. It should answer most of your questions.
Hydraulic Add-on Unit for NF Tractors
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
It’s already installed and I read it like stated in the post but thank you
For front implements, such as a snow/dirt blade, you will need to cut the lift paddle (that is what you have the you stated U bolts) in order to modify it. I do not know what you mean when you said the hole in the cylinder??? You should NOT have to drill any new holes in the paddle to use the implement lift. The only holes that you would need to drill are in the frame to mount the hydraulic lift itself and it sounds like you have already done that. You should be able to just bolt the lift paddle to your rock shaft bracket. I had to use longer spacers for my hydraulic lift, so I had to also make a modified lift rod that extends out, but you should not have to worry about that. Mine is because someone sold me an electric lift rockshaft, but told me it was for a hydraulic lift.
The float at the clevis allows the implement to "float" like the float button on the Armstrong lift handle. You should NOT use this with a snow/dirt blade on the front as you will want the down force in order to move the material and not float over the top of it. If it helps, look under my profile, look in "My Album", then "My Cubs". Go to page 3 and bring up my 123 Snow Ready (1st picture). Enlarge the picture and maybe that will help you examine the set up. or Looky Looky at the 1st pict of this "hydraulic" lift (the seller calls it a hydro lift, but that no is correct): https://www.ebay.com/itm/14287932031...MakeTrack=true Cub Cadet 123
Don't run the front blade with it locked down, or while using downforce. |
Put some weight on the blade to achieve "down force"
It will not then ride up over something so easily, but, it will more easily dig in and trip the blade spring option if it is not on the locked position. |
I float every implement I have. Mower, tiller, blade..........locking it breaks things.
| Thread Tools | |
| Display Modes | |
