View Poll Results: What color should the wheels be?
White Wheels 36 81.82%
Red Wheels 8 18.18%
Voters: 44. You may not vote on this poll
Old 01-01-2018, 09:58 PM
bfowler88's Avatar
bfowler88 bfowler88 is offline
My vote is red, great job so far!
1971 IHC Cub cadet 106
1982 IHC Cub Cadet 682 (looking for engine)
Old 01-01-2018, 10:00 PM
Originally Posted by cadetmike View Post
Well I cant decided to be honest...
plus I like to know what other peoples opinions are
That's fine then. I like factory colors but good luck.
Old 01-01-2018, 11:51 PM
Marko141's Avatar
Marko141 Marko141 is offline
It's either full factory or full custom for me, no in between.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 01-02-2018, 08:31 PM
cadetmike's Avatar
cadetmike cadetmike is offline
Someone please tell me what I am missing here! When I took the steering wheel off, this is all that was on the top end of the column. Seems like there should be some type of retainer to go up against that white bushing... or maybe the last guy put it together wrong?
Old 01-02-2018, 08:37 PM
There is a foam insert that goes in there, in between white piece and steering wheel. Some guys use a front wheel bearing in place of what you have, converts 2 piece into one piece bushing which also works but some gnurling needs to happen or some put in small amount of foil around bearing OD to keep it from working its way out. CC makes a plastic bushing that replaces the OE style sleeve and insert like you have. Looks up Parts breakdown and you will see.
Old 01-02-2018, 08:52 PM
cadetmike's Avatar
ahh ok thanks.
so you are saying I can remove the plastic piece
and metal seat it rides on and install a front wheel bearing with some
slight modification? that sounds like a good way to go
Old 01-02-2018, 10:06 PM
Gompers Gompers is offline
ahh ok thanks.
Check this out
https://youtu.be/--a0RYK65Yg
Old 01-02-2018, 10:47 PM
cadetmike's Avatar
great vid, thanks
Old 01-02-2018, 11:19 PM
You know what they say about "opinions"? There like a$$ holes, everyone has one.
I like the original look/color. That's my "opinion", and I'm stickin to it.
As Jeff wrote, "You have to look at it, pick what you want."
Old 01-06-2018, 05:18 PM
cadetmike's Avatar
Big thanks to Kelly for the WF front axle for the 122!!
More pics of the project coming soon.
