| View Poll Results: What color should the wheels be? | |||
| White Wheels |
36 | 81.82% |
| Red Wheels |
8 | 18.18% |
| Voters: 44. You may not vote on this poll | |||
I have decided to start a thread to keep everyone updated with my winter project. I plan on making several modifications to my 122 as well as making some repairs where needed.
- V-twin swap (need to get an engine yet) - drop and lengthen front frame section (for engine fitment) - fabricate an new front axle complete with 4-bolt trailer hubs (cast axel is shot, holes are all wollowed out) - repair shift forks (done) - possibly install 26" tires on the rear - repaint in red IH color scheme I am not completely sold on the rear tire swap, I have not seen many 122's with 26" rear tires, but I like the idea, so I need someone to convince me one way or the other. I also love the idea of creeper gears but they are hard to come by and not cheap (from what I have seen) here are a few pics of the project so far. I also included some of my custom sleeve hitch. IMG_0775.jpg IMG_0776.jpg IMG_0777.jpg IMG_0780.jpg IMG_0778.jpg |
It seems I have been persuaded to rebuild the k301 I have, rather than do the v-twin swap. that being said, I do love a good rebuild!
Also I think I will keep the 23" tires I have already on it and maybe peruse running dual's when not plowing. |
cadetmike Thanks for the pictures! Looks like a good functional rear lift. Nice to see the "before" pictures!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
While a creeper gear works great with a tiller , they are a weak link in the powertrain.
Jeff |
I sort thought it might be... thanks for the insight
Do be afraid to ask questions, BS answers are not allowed here.
Now if do decide to use one and you wear the spirol pin hole, I can weld it up and cut new snap ring grooves to save it. I can make parts if you need them too. Some of the parts I make are here http://www.onlycubcadets.net/forum/s...ad.php?t=20875 |
tore the front axle out and had a good look at it, pivot pin was rusted fast in the axle, had to cut it free of the frame then press it out of the beam
looks like I will need to drill out the spindle holes to 7/8 and install bushings, then I think I will build WF style spindles as they are stronger, with 1" shafts to take 4 bolt trailer hubs... sounds like a lot of work but I hate sloppy steering and such. And why didn't they ever put a grease fitting in the beam for that center piviot?
If you want to avoid the sloppy draglink issue and want stronger spindles, put a wide frame axle with 1" spindles and you will be satisfied. Bolt on hubs look cool but are overkill. Have fun with your toy!
Queen Of The Quietlines!
| Thread Tools | |
| Display Modes | |
