#51
Myself, I use inner tubes on anything that is not an automobile.
#52
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
#53
I tried the ratchet strap technique, but I didn't put soap or anything on the rim. I imagine that would have helped. I'll give that a try tonight prior to doing the big bang method. haha.
#54
Thank you sir. I'll look into that if the ratchet strap with soap doesn't work tonight. My wiring harness was delivered so I MAY have a running tractor prior to going to sleep tonight. *fingers crossed*
#55
I'm regretting not using tubes at this point.... Wish I would have.
#56
Alright. She's running... BUT, I have to start her up with a jump starter. She runs great when on the starter, but as soon as I take the jumpers off she dies. My battery is 100% crap. BUT shouldn't it continue to run on the generator? I'm assuming I've got a bad generator. Any other possibilities?
#57
Tec Section Library- Tractors page 4 “S/G Charge Test “ is a great place to start!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#58
#59
Either starter/generator or voltage regulator.
If I had to hazard a guess, it’d be voltage regulator/wiring.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
#60
If your battery is that bad, it will dead short the charging system. Replace the battery and see if it charges after that. A bad battery can cook other good components. |
| Thread Tools | |
| Display Modes | |
