I use 15w40 rotella and a little bit of Lucas in my 1572. I also suggest the kubota filter or a fleetguard filter. Also to lubriacte the top end of the cylinders and injector and injector pump use lucas fuel treatment int he winter and 2 cycle oil on summer in your fuel.
Justin
Rotella 15W40 is good stuff. Used to get 20,000 hrs on my Cats with it before overhaul and the bearings were still in spec. I use it in my Kubota BX as well as my gas engines. As far as filters I like NAPA gold or Wix filters. Just my 2 cents.
I use Rotella T 15w-40 in everything. Makes not having to keep 3 or 4 different weights of oils around. It doesn't hurt gas engines at all. Even my 444 Case calls for 15w-40 in the hydraulic system.
That all depends on what engine it is. Newer motors have very tight tolerances, and if you run that heavy of oil in them you can damage the bearings. The oil is too thick and just opens the bypass valve in the oil pump. Oil starves the bearings.
Oh.... and this thread is from 5 years ago..... |
102 soon to be tiller machine 108 mower 73 plow machine 169 soon to be mower 122x2 now parts machines Parts 129 149 parts 61 "O" 104 job to be determined ![]() ![]()
Much appreciated
| Thread Tools | |
| Display Modes | |
