Old 09-19-2010, 09:48 AM
mrcubcadet's Avatar
I would still rebuild the carb and get a temporary gas tank on it so you can definitely rule out a fuel problem. The idea is not to see if you can get it to fire/run with as many problems as possible, it's to fix the known problems so you can fix the unknown problems...
Yes, I will rebuild the carb.....but right now I am just seeing if it will fire with starting fluid (before I start doing much work to this tractor).
-105___ Tiller
Old 09-19-2010, 09:56 AM
mrcubcadet's Avatar
Originally Posted by hydrocub View Post
would you be interested in selling the grill off the 129 ?
If so pm me ...thanks in advance
I'd like to keep it on this tractor if I am going to get it going and use it.
-105___ Tiller
Old 09-19-2010, 11:45 AM
hydrocub hydrocub is offline
I understand .....thanks
Old 09-19-2010, 12:25 PM
mrcubcadet's Avatar
I just sprayed gas into the carb, and I heard it try to fire.
But I think one reason why it is having problems is because the S/G is turning real slow, I am jumping it with my 154 Lo Boy and the S/G on it turns fine.
-105___ Tiller
