#121
another tip; If there is a gasket available for something, USE IT!!! DON'T substitute RTV for a gasket.
#122
The newer engines don't have many gaskets. Most of a Duramax diesel is sealed up with silicone. The rest of the gaskets are stamped metal, no "gasket" material used. Silicone is becoming the common sealant used. |
#123
I work at a engine plant. We use Three Bond FIPG and we use robots to dispense it. It is different product for oil or water. There are a few gaskets but not many. We spray water on the lower oil pan to help it cure faster. We thought it was the dumbest idea we had ever seen, leaks went to zero. There was not enough time between leak test and lower oil pan installation.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
#124
There it is! That's cool. Can you say who's engine plant? Gas or diesel? What engine? Anything? I'm curious now. In Tennessee, I'm assuming either Nissan or GM. ![]() Not to get off topic or anything, but as a mechanic, I've always found it amazing the mass production process of assembling an engine. Just really amazing that they assemble them so fast and they run as long as they do. Comparatively, it takes forever to do a good rebuild of a motor in a shop. Sure, a lot of that is parts cleaning and machine work.... but even if you have everything sitting there it still takes quite a while to assemble one. You mechanics know what I mean. I mean.... how many motor are assembled in the factory a day? Hundreds right? |
#125
I pulled a late night last night and got this thing installed and filled up. Plumbing is all reconnected and linkages too. I went down to look this morning for leaks and so far its bone dry. I'll recheck the bolt torques to check for carrier and rear cover gasket crushing and make sure they're still snug.
IMG_3639.jpg It's about ready to put wheels on and push it outside to pressure spray areas I couldn't get to with the fender on before I reassemble any further. |
#126
And that is why a crate engine today, is less costly than rebuilding by a "mechanic" I've seen a tremendous change in things just since the early 1960's (sorry for the hijack) |
#128
#129
Do not do that. Those gaskets do not need to be crushed further. Kohler head gaskets are the one of the few things that need retorqued. Everything else is fine after the first time. Just leave it alone.
#130
Well..... your not a mechanic either. Believe me, it doesn't take 3 days to get to the valves on an Intrepid. Maybe 4 hours. And your wrong about the water pump failure that only leaks coolant into the engine. While I agree it is a poor design, there is a weep hole from the pump to the outside of the motor. What usually happens is some guy who thinks he's a mechanic changes the water pump and puts silicone on the gasket. That plugs up the weep hole, then when the pump fails the coolant can't go out where it's supposed to and ends up in the motor. I have seen it a few times that it was no one's fault.... like somehow dirt got in the weep hole on the block and plugged it up. But usually it's a previous mechanics fault. |
| Thread Tools | |
| Display Modes | |
