Old 04-21-2017, 06:46 PM
My guess is that with a bit of age they grow in size about 1-2 inches.
Highly unlikely.... tire rubber doesn't do that. They have belts in them.
Old 04-21-2017, 07:00 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Belts have belts in them too. They stretch. My guess is it would be the sidewalls that stretch. I am going to document this on the next set of front tires I replace.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-21-2017, 07:31 PM
Different kind of belting in a belt. Belts are designed to flex. Bias tires are not.
Old 04-21-2017, 07:42 PM
I have a belt and somehow I keep getting bigger.
Old 04-21-2017, 07:47 PM
I think that's a different problem....
Old 05-02-2017, 08:43 PM
tar1962 tar1962 is offline
You guys might get a kick out of this.
The tires I had purchased simply are a smaller tire. Same size by number as OEMs that were on my 1250. (btw I am well aware of the original OEM tires and NO they are no longer made) The style of Carlisle 4 rib I purchased are, by nature, smaller and this is difficult to determine until you have the tire in hand. Tire sizes can vary once mounted from what is stamped on them according to manufacturers. Mine looked like low riders up front once put on the 1250 and dropped the front of the deck considerably. Wish someone would have mentioned that when recommending the tires.
So...I purchased a set of V-61's and once they arrived I was able to tell they would be a better match height and width wise. I figured the Carlisle's could go on another of my 1250's that only plows snow and is already fitted with older Carlisle's of similar size.
I am not able to do the tire mounting so I took the lot of them to our Cub Cadet dealer to have the Carlisle's removed and the V-61's mounted.
Now, if you do the internet research, you will find that V-61's come in 4 and 6 ply versions at this size (16x6.50-8) and are the most popular Heavy Duty ribbed retro-fitted tires for Cub Cadets, Tri-ribs not withstanding. (these statements are heavily qualified so read carefully before contesting). The V-61 4-ply version is difficult to find. I saw them listed at one dealer in Wisconsin and that was it. The 6-ply are what Miller sell and have sold for many vintage Cubs. If you have a loader 6-ply are mandatory for load ratings anyway. 6-ply also allow the tires under normal use to be run with less psi before affecting ease of steering.
I no sooner get home from dropping the tires off and the Cub Cadet dealer calls saying that they cannot mount the tires on the rims. I drive back there and they say that the V-61's are the toughest front tires they have ever seen. Not only this but, they apologize for scraping-up the paint on the rim they tried mounting. These are OEM rims that I took the time to correctly prep, paint with Rustoleum Appliance Epoxy, and allowed to cure for two weeks before mounting the Carlisle's. Now I have a rim to re-paint and no clue where to take them to have the V-61's mounted. Hard to believe considering how popular the V-61's are but the Cub Cadet dealer was clueless.
This seems crazy to me. If you were to look before commenting you would see V-61's raved about throughout this forum. Pictures and plugs for purchasing them at Miller are found throughout all garden tractor forums. Also, before commenting, think in terms of the fact that you do not know me. Any comments about OEM or my lack of familiarization with what is OEM is short sighted. What I could use are comments from those who have actually mounted or have had mounted Vredestein V-61 6-ply tires on wide OEM Quiet Line rims. My 1250 is equipped with 1" spindles and the rims were taken from a 1650 by the former owner before I owned this tractor.
To be honest, a couple of responses after my first thread were condescending. I believe you guys can do better than that. There are a lot of people who read your forum. These folks can figure out who the experts are over time and they rely on the experienced information you guys can provide.
Hint-that's not a dead horse in this case.
Old 05-02-2017, 09:18 PM
sir_lancealot sir_lancealot is offline
According to the Vredestein website, the 16x6.50-8 only comes in 6 ply. The larger 18x8.50-8 come in 4 and 6 ply. I don't know what that one dealer had listed, but they must have been wrong.
http://www.vredestein.com/agricultur...ter/v61/sizes/
Try a different shop? Maybe go to an actual tire place? They should know how to mount/dismount any tire. If it's outside of the "ordinary", lawn mower shops probably don't know how to handle it.
Old 05-02-2017, 09:24 PM
I take my tires to a shop that does big rig and farm tractor tires, they charge me $5 each and haven't scratched a rim yet.
Old 05-02-2017, 09:28 PM
john hall's Avatar
I'd waste a phone call to Miller and see if anyone has ever complained of such a problem and what the popular tricks to mounting them are. How about trying an independent tire shop-one that mounts all kinds of tires. Those guys should know all the tricks of the trade.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-02-2017, 11:47 PM
I do plan on going to a tire shop tomorrow and I will be calling Miller. I also saw that Vredestein didn't list a 4-ply and I have never heard anyone refer to their V-61's as 4-ply. After I get the front tires dealt with I still have to switch to AG's in the rear. At this rate the lawn will be a meadow before I get out there. Fortunately, I have had time to recondition the trunnion springs and repair the arm already and without welding!
I do appreciate your help. Going through the rim painting process again will mean it will be some time before I can move forward. I will let you know how it goes.
Tags
1250 front tires
