Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 02-21-2017, 01:18 PM
Default Plowed the garden today.....
Ok, so I did it yesterday.
Is it unseasonably warm and dry anywhere else?? It's NEVER this warm in February. Honestly, the years I can remember it being this warm in February the rest of the year wasn't good. Either HOT and dry (as in drought) or warm and rainy into June. Hopefully it will just be like the almanac predicts..... a mild summer.
Anyway, I figured I'd get a jump start on the garden and turn over the fodder so it can rot. I won't plant it for a while. Next week it's supposed to return to colder temps.
Pics, cause it happened!!
Old 02-21-2017, 02:32 PM
Terry C's Avatar
Terry C Terry C is offline
Very warm here for the last two weeks. 71 today and it's a record.
Hope that almanac is right.
The plowing looks good!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-21-2017, 07:54 PM
john hall's Avatar
Its dang near hot here, for Feb. Not supposed to get below freezing for over a week. We normally see 1 or 2 days in Feb that hit 70 deg. By the time this weeks over it will probably be around 10. I chisel plowed about 7 acres of corn land this afternoon--no mud at all. I have seen that field be muddy from Oct to March--drove right through a wet weather spring like it wasn't even there. I got a feeling we are in for a drought this summer.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Did the "skinnies" improve the traction?
Queen Of The Quietlines!
Old 02-21-2017, 08:05 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
So thats what you were doing! Looks like fin! Was 76 here on monday, hit 70s every day this week. Turns to shit this weekend tho.
1- 1200 in pieces
1- 1864 in pieces
Old 02-21-2017, 08:35 PM
I hope your wrong..... but I have the same feeling. Every time we had a Feb like this, that's what happened.
On the rear? Yes. Narrower tires have more pounds per square inch on the ground. I get same or better traction with those non-lug 6's than with a 10.50 lug. On a big farm tractor that has lots of weight, you can usually go to a larger tire and improve traction, but there is always a point of diminishing return. A Cub is no different. Comparatively, the difference between a 6" tire and and 10.50" tire is like the difference between a 18.4 farm tire and a flotation tire. Like I said, I'd prefer an 8.50, but that has more to do with ride than traction. (The 6" tires tend to "teeter" side to side more. At least on this tractor.) Plus, an 8.50 holds more fluid.
Old 02-21-2017, 10:19 PM
Nice work Jon. Looks like you gave the right arm a good workout.
Old 02-21-2017, 10:54 PM
You know, funny you say that because it's my a$$ that's sore!! Riding sideways on that seat is hard on ya!!
Seriously though, I put spring assist on it last year, so the plow lifts easy. Tiller..... now that sucks! Even with the spring assist cranked down, it's still hard to lift!
Old 02-22-2017, 07:35 AM
Well done JB! Wish I had soil like you have.
Old 02-22-2017, 12:31 PM
rocker582special's Avatar
rocker582special rocker582special is offline
Is the 1050 like the 582 Special? If so, any chance you can send a picture of your sleeve hitch setup?
Rocky
Cub cadet 70,123(parts),125,582Special
