Old 01-21-2017, 04:55 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Default The "72"
I have this little 72 that was used, abused and put outside. It is a cutie but needs some attention. So...here it is!
The process has started...
Queen Of The Quietlines!
Old 01-21-2017, 04:59 PM
DeltaCub's Avatar
The engine is apart and ready for the machine shop....usual stuff...cylinder bore...turn crankshaft and clean up ends...reface valves and recut valve seats...check valve guides.
Bearing on crank will be removed prior to machining.
Old 01-21-2017, 05:53 PM
CubDieselFan's Avatar
Looking good, keep the pictures coming.
Old 01-21-2017, 05:54 PM
Nice! I like projects, and 72s.
Old 01-21-2017, 06:04 PM
Are you going to paint the twactor?
Up to 530 and counting...
Old 01-21-2017, 06:16 PM
DeltaCub's Avatar
Yes, indeedy...after a great deal of repair!
Old 01-21-2017, 06:50 PM
Nice job Brianna. Was it a smoker?
Old 01-21-2017, 07:04 PM
DeltaCub's Avatar
I am sure it was...big score in cylinder wall. The tractor had been parked outside for an unknown amount of time resulting in messed up carb and a rotten wire harness. I never tried to start it.
Old 01-22-2017, 01:05 AM
Good project Beth. Gotsta love those little buggers.
Should have one of the mods move your thread to the IH Cub Cadet GT section, right up front.
Old 03-30-2017, 10:59 PM
DeltaCub's Avatar
Default Update on the little "72"
The engine is mostly complete...I need to take it back to the machine shop and have the valve stems ground for proper clearance. It has been bored 0.010 over, crank turned, valves refaced and valve seats ground. Block was hot tanked and cylinder head refaced.
Starter/ generator has been completely rebuilt too!
Chassis has damage and that will need some welding.
Lots of little parts that I blasted in my Skat Blast cabinet almost ready for paint.
