Old 09-05-2010, 10:16 AM
buddylee64's Avatar
buddylee64 buddylee64 is offline
Default rear axle issues
I picked up a 169 with a bad axle seal. My question is where would I get these parts from. I was going to try to go to the local NAPA parts store and see what they had. This is my first time doing an axle seal and i am surprised how simple it really is. just one locking ring hold the axle in place. Where would be a good place to get seals and gaskets. thanks
Old 09-05-2010, 10:29 AM
CMA's129's Avatar
CMA's129 CMA's129 is offline
I would try the local cub dealer first. Your going to need an oil filter and five quarts of Hy-tran oil plus a cover gasket as well.
Where are you located in PA? Mabye I can help you with a source.
"Good Dogs Never Live Long Enough!" Casey Angeletti
Old 09-05-2010, 10:43 AM
First, you can try your local Cub Cadet or Case-IH Dealers.
If that is not feasible, then any of the Sponsors in the boxes at the top of the page would be more than happy to take care of you.
Old 09-05-2010, 10:58 AM
A 169 holds 7 quarts of Hytran. Get a 2-gallon container from a Case-IH or Case heavy equipment dealer; it's cheaper than buying quarts from CC. Replace both axle seals while you are in there. I would also get the top cover gasket so you can refill the trans through the top. It's MUCH faster.
Old 09-05-2010, 11:05 AM
CMA's129's Avatar
Sorry about that, Matt is correct 14 pints. If you have someone to hold the funnel you can put it in the plug in a couple of minutes. Less time than it takes to scrape off an old gasket.
Old 09-05-2010, 02:26 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Try Napa 9878.They worked extremely well for me and were about 5-6 bucks a piece....
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 09-05-2010, 06:26 PM
buddylee64's Avatar
thanks guys.. very helpful...... my next question was if any one filled the tranny from top plate... lol
Old 09-05-2010, 06:38 PM
Merk Merk is offline
I use a funnel with a tube connected to it to fill rear end.
